What is correct wire size
Old 01-05-15, 08:12 AM
R
I have an older Sears compressor that says the motor pulls 7.5 amps. Can you tell me what gauge wire I need to use to the plug?
Currently, it has about a 4 ft 14 gauge power cord. I want it to be longer. 14 gauge seems considerably large. I would think a 16 gauge would be adequate but wasn't sure about the startup current pull.
The current cord is a replacement so I have no idea what originally came on the unit and the manual does not state what it is.
Thanks,
Rut
Old 01-05-15, 08:42 AM
I
Received 45 Upvotes on 43 Posts
The #14 seems like the appropriate size.
Old 01-05-15, 09:15 AM
Received 1 Upvote on 1 Post
No way would I go smaller then 14.
Old 01-05-15, 05:14 PM
F
Depending on the length I, too, would use nothing less than #14. If more than 25 feet I would use nothing less than #12.
