Is this old telephony equipment?
Old 01-05-15, 02:40 PM
K
I found an ugly mess of wiring in my basement, in the utility closet which houses the water and gas meters. It looks like some sort of large metal lug with 3 conductors, sitting under a beige plastic box. All around it are what look like both low voltage telephone wires as well as high voltage electrical.
The house was built in 1969 and contains some remnants of aluminum wiring (I understand that that is another issue entirely). The house currently has 1 working telephone line; I can't say whether there may be a second unused line wired up.
Does anyone recognize what this may be? My non-contact voltage tester tells me there is some electrical activity in these wires. But there are so many wires jumbled together that it's hard to determine the source.
Here is a link to the photos (too large to upload here): http://imgur.com/a/Mt99m
Thanks!
Old 01-05-15, 02:57 PM
I
Received 45 Upvotes on 43 Posts
It's definitely all phone wiring. The beige box looks to me to be a transformer for ringer/light power on the old Bell phones.
Old 01-05-15, 03:23 PM
N
yes, that is telephone wiring. the block is commonly referred to as a protector, it provides overcurrent protection. it generally is installed at the junction of the outside and inside wiring. the white "transformer" does NOT apprear to be telephone related to me. if you read approximately 48 volts dc accross the two outside connectors on the protector (the center lug is ground) it is live.
Old 01-05-15, 06:14 PM
Received 3,898 Upvotes on 3,494 Posts
The transformer is power for an alarm system. The brown conductor cable goes to the alarm system dialer jack. The phone line is sent to the alarm first on the red and green wires. It then returns from the alarm system jack on yellow and black. This is setup like this so that the alarm system seizes the phone line in case of an emergency communication or alarm transmission.
Old 01-06-15, 10:59 AM
K
Thank you all for the comments. And thanks especially to PJMax for the thorough explanation and graphic. That makes a lot of sense, considering the house had an old/unused alarm system that was still installed (but no longer working). This will be good to know when we get to remodeling the basement.
