question about adding a switch
Hello here is my question....
I would like to add in the end off the circuit a switch. with This switch i want to control only the last light ( is light with chain)
The power came from the panel to the existing switch after that i have three lights( the last one is the light with chain. The circuit that i have is not a 3 way circuit.
Any idea if i can do that? With a 2 way circuit
Thanks!!!
Thanks!!!
You currently have three lights ALL controlled by the one switch ?
You could add a switch to the last light but if the main switch controls all three lights..... all you can do is turn the light off if the main switch is on. If the main switch is off.... all three lights will be off.
