12V circuit using 120V light fixtures
Old 01-09-15, 07:42 PM
N
I have low voltage lights outside and I'm looking to add pillar lights. Only 'nice' models I see are 120v models. Can I use these light fitting with 12V circuit if I use 12V DC LED bulb in the fixture?
Old 01-09-15, 08:35 PM
Received 761 Votes on 715 Posts
Welcome to the forums.
You can use a standard 120v post/pillar light for 12v use but you may not find the type of lamp you want. You need a 12vdc LED with an A19 socket unless you plan to remove the existing socket.
super bright leds/search/led-household-bulbs/a19
Old 01-11-15, 04:55 AM
R
Yep. They make them for campers and boats. Here are more examples:
https://www.superbrightleds.com/cat/...,E26E27,1,448:
