3 Way Half Switched Outlet
Old 01-09-15, 09:05 PM
I am looking for a wiring diagram or checking if it is possible to wire a 3 way half switched outlet with the following wiring configuration:
Panel -> 12/2 -> Switch -> 12/3 -> Switch -> 12/3 -> Outlet
Thanks in advance
Old 01-09-15, 09:46 PM
Received 3,891 Upvotes on 3,488 Posts
Welcome to the forum.
No....your wiring will not support a 1/2 switched receptacle.
Your 12/2 brings power to the first three way switch. The 12/3 between the three way switches carries your two switching travelers and neutral. You are not carrying an always live wire past the first switch.
If you could locate 12/4 cable then you would use it between switches and you could have a 1/2 switched receptacle.
Old 01-09-15, 09:56 PM
That is what I was afraid of. I wasn't sure how to bring a constant hot between the two switches. Thanks for your response.
Old 01-10-15, 01:51 AM
Handyone's Avatar
You can run a separate 12/2 from 1st switch box (source) to receptacle.
