Rules for drilling through double joist
Old 01-13-15, 07:12 AM
B
I want to run power to a light at the bottom of my basement stairs. To get there, I need to drill through a double joist which is likely part of a load-bearing wall. Am I allowed to do this or should I figure out how to route my wire around the long way to avoid drilling? Thanks.
Old 01-13-15, 07:25 AM
Received 747 Votes on 702 Posts
Welcome to the forums.
One 3/4" hole for one wire would be be no problem.
Old 01-13-15, 07:31 AM
pcboss's Avatar
Received 63 Votes on 55 Posts
Are you planning on a vertical or horizontal hole?
Old 01-13-15, 07:37 AM
I
Received 42 Votes on 40 Posts
Some joist & stud drilling guidelines:
Old 01-13-15, 09:30 AM
B
1 horizontal hole on the outer 1/3 will do it! Thanks for the welcome and the info!
Old 01-13-15, 10:36 AM
pcboss's Avatar
You do not want the holes in the outer portions.
Old 01-13-15, 11:59 AM
B
In the graphic that ibpooks showed, it looks like it doesn't matter, except for notches which is not what it am doing. Is that not the case?
Old 01-13-15, 03:29 PM
Tolyn Ironhand's Avatar
Received 133 Votes on 117 Posts
It is more of an issue for a plumber drilling out a 4" hole. Electricians mostly make smaller holes.
Old 01-13-15, 04:39 PM
Handyone's Avatar
The graphic above shows the outside edge of hole at least 2" away from bottom or top or joist.
This is not only for integrity of joist (especially small electrical holes), it is to place cable in a position where getting hit with a screw or nail is unlikely.
Notching requires nail stop plates.
Old 01-13-15, 06:06 PM
pcboss's Avatar
A hole centered top to bottom weakens less than one closer to the edges.
Old 01-13-15, 06:08 PM
B
So my plan of a small hole, outer 1/3rd of the joist, would be fine as long as I am > 2" away from the top or bottom. Thanks!
