Are my AC Armored cables OK to reuse?
Old 01-14-15, 08:50 AM
W
Hi,
in the process of replacing a disposal, the old one was hardwired & I decided to place a surface mounted receptacle under the sink. Most of the disposals that fit our area under the sink came with a three prong plug. Seemed better to install an outlet for future use as well.
After removing the old disposal (probably 20+ years old) & pulling the electricians tape off the wires I noticed some frayed sheathing. My first thought was the outer sheath of the wire decayed, but now realize it's just paper wrap I unraveled removing the old electricians tape. Have since discovered this is called "Kraft" paper wrap.
I cut back some of the armor to expose wire/wrap underneath, this is when I realized it wasn't the outer sheath of the wire decaying but in fact a paper wrap.
My questions are:
#1) looking at the pictures do you think the wires are too old to reuse? Or do I need to install new AC cable for new disposal?
These are prior to cutting the armor.
This is after cutting the armor. Can clearly see more Kraft paper wrap which obviously not part of the underlying (I guess) plastic cover.
#2) The short cable was attached to what appeared to be a ground screw in the old disposal. Some confusion on whether a ground wire is required when a bonding wire is present. But I have found info stating that the bare bond wire is not an equipment grounding conductor. In which case I would still need to connect the ground (shorter) wire.
Thank you
Old 01-14-15, 09:06 AM
pcboss's Avatar
Received 192 Upvotes on 168 Posts
It looks to me that those cables are past their lifespan and should be replaced.
Old 01-14-15, 09:41 AM
I
Received 45 Upvotes on 43 Posts
I don't know that you would strictly have to replace them given this is a repair situation, but the cable looks to be in pretty bad shape. I wouldn't feel very good about reusing that one. Once upon a time all of that frayed fiber was a tightly wrapped cloth sleeve over the wires. The material is very broken down and decomposed. The insulation underneath is probably a natural rubber which dries out and cracks apart at this age.
Old 01-14-15, 10:30 AM
Geochurchi's Avatar
Received 159 Upvotes on 145 Posts
How much slack in that cable? Cut the armor back as far as possible and see what it look's like,is that a 3wire cable ?
Geo
Old 01-14-15, 10:38 AM
W
Yes it is a 3wire cable. I did already cut back an inch & one half or so. Afraid if I go much further won't have enough to reach the other side of the cabinet where I want to install the outlet.
So including another handyman forum I posted to that is a total of 4 votes for replacing the cable. Was hoping I'd get another response here but sounds like I got the right one to begin with.
thank you
Old 01-14-15, 03:36 PM
Geochurchi's Avatar
I would also agree, I was hoping you may be able to get a Ft. or so cut back,is that a home run back to the panel?
Geo
Old 01-14-15, 04:06 PM
W
No it goes to a switch beside the sink. Right now I'm waiting on some help as how to best replace. One suggestion was to possibly use the old cable & run new wire thru it.
My thread at handymanwire is Can I surface mount an electrical box under sink?
Sorry if posting similar question to both forums is inconvenient or wasting anyone's time.
Here are some pics:
By the way not one person said OK to reuse old AC cable wires. All said they need replacing. Both forums giving pretty consistent / good advice.
Old 01-14-15, 04:09 PM
W
to ibpooks,
The natural rubber underneath is dry & appears to be cracking upon closer inspection, just as you suspected.
