Light does not turn off
Received 0 Votes
One of my light fixtures is not turning off when I turn the switch to the off position. This had always worked before, and there has not been any re-wiring of any sort. The switch has a dimmer, which works fine changing the glow of the light, however I am not able to turn it off.
Any ideas? Thank you
Received 0 Votes
I assumed that since the dimmer on the switch works, that the switch would also be fine. I will try to purchase a volt ohm meter tomorrow.
What type of results should I expect to get from the meter?
Thank you
Thank you
The ohmmeter should show no continuity when switch is off but without knowing exactly what type of dimmer/switch you have there I can't offer much further help.
I would replace the dimmer. At this time that Lutron dimmer is still available.
White 1 Pole Preset Toggle Dimmer MODEL #TG-600PH-W
