Waterproof knock out tie down for meter main
Old 01-18-15, 07:22 AM
Z
I'm putting in a new outdoor meter main and I'm going to run #6 bare copper to the grounding system. What is the best way to come out of the steel panel? Do they make waterproof 1/2 knock out clamps or should I just use a regular one? Also looked like the panel has 1/4" knock out holes? What do people do on their meter main to get the ground wire out of the box?
Old 01-18-15, 07:25 AM
Tolyn Ironhand's Avatar
Received 676 Upvotes on 573 Posts
Go out the bottom. Drill a hole if needed to fit the wire through.
Old 01-18-15, 08:01 AM
chandler's Avatar
Received 9 Upvotes on 8 Posts
No need for a clamp for the grounding electrode. Use one of the knockout holes in the bottom (1/4") or drill one as Tolyn indicates. From the meter base to the panel, if you are back to back, and using a 2" nipple, just run it through with the other conductors.
Old 01-18-15, 08:10 AM
pcboss's Avatar
Received 163 Upvotes on 142 Posts
Check with your inspector. Some areas require a clamp like the Kenny clamp.
Old 01-18-15, 08:13 AM
ray2047's Avatar
Link: Kenny Clamp 2011 NEC compliant
Old 01-18-15, 08:38 AM
chandler's Avatar
Yeah, since your profile is incomplete and we don't know where you are located, a clamp may be required. Fill us in on your location.
Old 01-18-15, 09:22 PM
Z
How is that? I'm in Portland Or in unincorporated Washington County..
Old 01-19-15, 03:42 AM
pcboss's Avatar
Some areas may have local rules that change the NEC. Location matters. For example, areas around Chicago require conduit and NM cable is not allowed.
