Need a timer for 240v irrigation well
Old 01-18-15, 02:24 PM
Hello,
I live in Fremont County, Colorado. I am looking for help with finding a timer/relay for my 220v, 5hp, 28amp, 70gpm agricultural irrigation well. The existing control is a set of 2 -30amp circuit breakers in a Siemens A series type 3R outdoor load center. I want to be able to set the pump to run daily for 30 – 60 minutes during the growing season. Can anyone suggest a timer/relay, and/or combination, that would work for this application?
Thanks,
Matt G
Old 01-18-15, 02:58 PM
Received 3,422 Upvotes on 3,068 Posts
Welcome to the forums.
You mentioned the type 3R outdoor load center..... was that for size requirements ?
You need a basic timer and a two pole motor duty contactor.
There are many choices.... will you be purchasing at an electrical supply house or online ?
Old 01-18-15, 03:29 PM
chandler's Avatar
Received 9 Upvotes on 8 Posts
I use this type for my diesel engine heater. Selectable voltage. GE, 7 Day Digital Outdoor Box Timer and On/Off Per Day, 15136 at The Home Depot - Tablet
Old 01-18-15, 07:11 PM
CasualJoe's Avatar
Received 173 Upvotes on 156 Posts
It sounds like you need a basic single phase starter and a basic timer. You may be able to get away with a definite purpose contactor rather than a full blown starter.
Old 01-19-15, 04:41 AM
Geochurchi's Avatar
Received 158 Upvotes on 144 Posts
How is the pump controlled now,you must already have some sort of Contactor to control a 5 HP pump.
Geo
Old 01-19-15, 05:33 PM
Thanks for the responses
The pump is controlled by a pair of 30 amp circuit breakers in a type 3r outdoor load center which was in place when I purchased the property. I was hoping someone could recommend a specific model/part number of timer and contactor that I could buy online.
Old 01-19-15, 06:40 PM
CasualJoe's Avatar
Why don't you just stop by your local electrical supply house, I am sure they'd be happy to help you, but they would also expect you to buy from them.
Old 01-19-15, 07:31 PM
Here is the contactor I would recommend.... EATON C25dnf240a
amazon/C25dnf240a-Definite-Purpose-Contactor-Terminals/
A good quality 40A 240V contactor with a 120vac coil.
Here is a timeclock.... same one Larry recommended....
Amazon: GE 7-Day On/Off Outdoor Metal Box Timer
And a weatherproof box to house the contactor...
Ipex077664 PVC Junction Box 8" x 8" x 4" - - Amazon
200mmx200mmx130mm Waterproof Plastic Sealed Electric Junction Box Case - Amazon
amazon/Plastic-Electrical-Enclosure-Junction-250x200x100/weatherproof box
Old 01-20-15, 08:35 AM
Geochurchi's Avatar
Is this pump above ground,is it thermally protected? 1 pump with 2 30 amp 2 pole breakers?something seems odd, can you post pic's of that setup?
Geo
Old 01-20-15, 08:42 AM
CasualJoe's Avatar
I don't believe the OP ever mentioned the breakers as being 2 pole. I suspect he has two single pole 30 amp breakers. Yes, a picture would help to clarify.
Old 01-20-15, 09:35 AM
Geochurchi's Avatar
I guess I took that for granit,but still would be nice to know if it is a submersible , if not is it thermally protected ,that would help determine the type of control necessary.
JMO
Geo
Old 01-21-15, 06:46 AM
CasualJoe's Avatar
I agree. That is why I said.....
The keyword here being "MAY".
Old 01-21-15, 03:53 PM
Pump info
The pump is a 5 hp submersible at approximately 60 feet. I believe the circuit breakers are single pole breakers, but I'm not an electrician, so I can't say for sure.
Old 01-21-15, 05:56 PM
Geochurchi's Avatar
Are these breakers inside a dry location?first change the single breakers to a 2 pole 30amp,assuming this is in a dry location you could use a controller such as this,gives a little more motor protection
http://www.amazon.com/Magnetic-Start...B004TGTU0W,and a time clock such as this.Amazon.com : Intermatic T101 24 Hour Dial Timer, Indoor Only : Swimming Pool Heater And Heat Pump Parts : Patio, Lawn & Garden
Post a pic of the breakers
Geo
Old 01-24-15, 06:38 AM
Thanks!
That looks like exactly what I was looking for.
