Where should I put the light switches??
Old 01-18-15, 04:52 PM
R
Question Where should I put the light switches??
I only have enough room to put a single gang in the place that I would like to place 2 switches. Can you put 2 switches in a single gang box? If not, what do people do in this situation? I do have room around the corner for a switch ( as you can see in the picture) but it isn't ideal.
Old 01-18-15, 05:13 PM
Received 3,420 Upvotes on 3,066 Posts
Ok.... and that would be where in the picture ?
Old 01-18-15, 05:39 PM
R
I uploaded a new picture. Spot 1 is where I would like to put the two switches. Spot 2 is the not so ideal spot. I can not put it on the opposite side of the door because the door will open in the direction.
Old 01-18-15, 05:46 PM
pcboss's Avatar
Received 163 Upvotes on 142 Posts
What if you put it in spot 2 but faced it out into the hall?
Old 01-18-15, 06:09 PM
Location 1 is less than ideal as it would be hard to sheetrock, finish the corner and get the plate to fit.
Old 01-18-15, 06:14 PM
B
They make double switches, like this:
http://www.amazon.com/Leviton-Dual-S.../dp/B0006B55DA
Old 01-18-15, 06:28 PM
R
PCboss, the other side wouldn't work for my needs. The switches are to control the lights within the room.
PJmax, I have 7 1/2 inches to work with. The trim for the door is only 2 1/2".
Brian Kramer, THAT LOOKS LIKE IT SHOULD WORK!
Old 01-19-15, 03:22 AM
chandler's Avatar
Received 9 Upvotes on 8 Posts
You'll have an additional 3/4" (really 1/2" considering reveal) to the left taking into consideration the door casing, so that location with an over/under switch would work.
