Wiring a cadet heater
Old 01-19-15, 09:26 AM
R
I am installing 2 cadet heaters that are 1500/2000 watt with built in thermostats and my question is, can I daisy chain the second one off of the first or does it have to be on its own circuit, I am using 12/2 wire and a double 20 amp breaker.
Thanks for any help you can give me
Old 01-19-15, 10:04 AM
CasualJoe's Avatar
Received 185 Upvotes on 166 Posts
Assuming 2000 watts @ 240volts, 2 heaters is more than you can put on a 20 amp circuit.
