Need help replacing thermostat
Old 01-19-15, 11:23 AM
D
First off, bare with me as i am not that savvy with electrical.
I am trying to replace an old 1970's thermostat for baseboard heaters. It has the turn style knob on it. I went to Lowes and purchased a digital Honeywell thermostat made for baseboard heaters. Here is what i bought Honeywell RLV3100A1017/E Non-Programmable Thermostat for Electric Baseboard Heaters - Nonprogrammable Household Thermostats - Amazon.com
The new thermostat comes with instructions for a 2 wire or 4 wire install, my old thermostat has 6 wires going to it. Hence, why i need help. Here is a very basic layout of my old thermostat and what it looks like from the front.
For reference, the 4 small circles are screws and the lines from the side are the electrical lines going to the screws. The lines on the right are all dark grey and the lines on the left are all white (in reality).
The back of the new thermostat has 2 black wires coming out of it. I need to know how to hook the 6 wires up so it will work.
The room i am doing this in has two 5 or 6 ft baseboard heaters in it, if you need to know that.
Any help you could provide would be appreciated!
Old 01-19-15, 11:31 AM
D
Maybe i should also note that i have a multi-meter and it reads 240 when placed on the top two "line" screws. If i place a probe on one of the line and one of the load screws it reads 94 or somewhere close to that. Not sure if this matters or not.
Old 01-19-15, 06:57 PM
CasualJoe's Avatar
Received 185 Upvotes on 166 Posts
I would pigtail the "Load" wires so you only have one wire per screw and then follow the 4 wire instructions. BTW, you link doesn't work.
Old 01-19-15, 10:16 PM
Received 3,891 Upvotes on 3,488 Posts
Connect the three white wires together.
Connect the two black load wires together to one thermostat wire.
Connect the single line black wire to the other thermostat wire.
Old 01-20-15, 06:12 AM
D
Thanks for the reply guys. That's what i thought i should do but i guess i needed the reassurance that it was the right thing to do. Definitely do not want to mess up wiring and heat in the middle of winter
The link works fine for me. Here is another to Honeywell's own website RLV3100A
It's the RLV3100A if you can't get either to work.
Old 01-20-15, 09:15 AM
CasualJoe's Avatar
It works for me today too, but wouldn't work yesterday.
