Wiring 240vac table saw motor
Received 0 Votes
Hello,
I have a 240V single phase motor that goes to a table saw which I'm wanting to wire back up but I don't have a wiring diagram. The motor has 4 wires, 1 brown with 2 connections available, 1 black, and 2 blue. One of the blue and the black are tied together. The resistance between the brown and blue is 15 ohm. The resistance between the brown an black/blue is 5 ohm. The saw itself has a brown wire, blue wire, and green wire which is earth. There's also a large capacitor. I'm wondering if someone could shed some light on how to hook this up?
Thanks.
Thanks.
Welcome to the forums! Your profile is incomplete so we don't know where you are located. From your description of your wiring you are on a 220 volt 50 Hz system. You have a 240 volt motor, that is possibly not compatible to your wiring system. Let us know where you are located.
Received 0 Votes
I'm in bolivia. We use 220 here.
Previous Thread
Next Thread
