Adding an outlet to unfinished basement
Old 01-24-15, 09:34 PM
W
I want to add an outlet to my unfinished basement. Currently, there is a single 15 amp circuit in the basement that has 6 lights and 3 outlets on it.
1. Can I even add an outlet to this circuit, capacity wise?
2. If so, do I need to find the end of the circuit and go from there, or can I simply pull from the closest junction box? In other words, does it need to be in series with the rest of the items on the circuit?
Thanks
Old 01-24-15, 10:03 PM
Received 1 Upvote on 1 Post
In the US there is no limit to how many outlets that can be on a circuit.
What do you plan on doing down there?
If I had of wired it there would have been at least two circuits, one for the lights and one for the outlets, and the outlet circuit would have been with 12-2 wire GFI protected and a 20 amp. breaker.
Old 01-24-15, 11:26 PM
Received 3,898 Upvotes on 3,494 Posts
Technically, by code, the receptacles in an unfinished basement should be GFI protected.
You can connect into the circuit at any convenient location.
Old 01-25-15, 04:30 AM
ray2047's Avatar
Well technically both the lights and receptacles are outlets.
Old 01-25-15, 09:02 AM
pcboss's Avatar
Received 194 Upvotes on 170 Posts
What is the expected load that will be on the new receptacle? It might make sense to add a new circuit.
You can branch from any unswitched part of the circuit that has space in the junction box for an additional cable.
Old 01-25-15, 02:22 PM
W
I'm planning on putting my office down there. So there will be a couple of monitors and computers on this new receptacle. It's a fairly small space, but I'm wondering if I should just bite the bullet and pull two receptacles on a new circuit instead of trying to mess with adding to the existing circuit. The majority of the space is not framed in, so there's very little room to even put the receptacles. I don't have any plans to finish it so I'm just trying to get it to a point where I can use it.
Old 01-26-15, 09:51 AM
CasualJoe's Avatar
Received 185 Upvotes on 166 Posts
I would just add a new 20 amp circuit.
