Ground up or down on electrical outlet
Old 01-29-15, 12:41 PM
Lightbulb Ground up or down on electrical outlet
This debate have been going on for a while now. I would like to know your thoughts on either to have the ground on the outlet up or down?
http://youtu.be/EmVH5En6x6o
Old 01-29-15, 01:29 PM
I
Received 45 Upvotes on 43 Posts
The position of the ground pin is really irrelevant as an arc flash can happen in any configuration when metal touches metal. Had the demonstrator's screwdriver been at a slightly greater angle there would have been flash between hot and ground just like between hot and neutral. A far better solution is to follow the codes and use GFCI protection and AFCI protection where required and never work on live electrical equipment DIY.
Old 01-29-15, 02:41 PM
Talking
I guess this could solve it.
Old 01-29-15, 02:47 PM
G
Received 2 Upvotes on 2 Posts
Welcome to the forums.
Do you have a question?
This forum is not about surveys but is about helping solve problems.
Old 01-29-15, 03:55 PM
ray2047's Avatar
Actually the safest position is ground on the left. The ground and neutral blade will deflect the falling metal object away from the hot blade.
Old 01-29-15, 04:58 PM
T
I would keep ground up. I wouldn't want people to get shocked and then get sued..lol
Old 01-29-15, 05:21 PM
ray2047's Avatar
Any documentation of a suit based on ground orientation? How would such an incident even occur? What would the basis of the suit be?
One actual problem of ground on top: Most residential right angle grounded plugs are made so the cord hangs down when the ground is on the bottom
Old 01-29-15, 07:02 PM
CasualJoe's Avatar
Received 179 Upvotes on 162 Posts
My thought is that it makes absolutely no difference and is strictly personal preference. That being said, my preference is ground down in residential applications and ground up in commercial.
Old 01-29-15, 07:10 PM
T
We live in a world of I'll sue you for any little thing that goes wrong. But there's been plenty of times I saw the incident occur. On the jobsites where plenty of extention cords were just leaning out of the outlet and with the welders and iron workers working above. It just took little pieces of metal to cause an arc or blew up the outlets. Lucky most were gfci protected but not all.
Old 01-29-15, 07:28 PM
CasualJoe's Avatar
So what does that have to do with ground up protecting someone from a lawsuit? Not a thing.
