GFCI outlets in unfinished basement
Old 01-29-15, 07:41 PM
D
My research now tells me GFCI is now code in unfinished basements.
I also see many debates concerning having a sump pump on the GFCI, the theory being when needed it could trip with flooding being the consequence
I want to keep at least one outlet non GFCI for the sump pump use.
My idea is to keep the first receptical on a chain of 4 outlets non GFCI via a pigtail splice, the second on the chain will have the GFCI which will be protecting the remaining two downstream. Is this proposal OK?
Thanks for the advice
Old 01-29-15, 08:28 PM
ray2047's Avatar
There are no exceptions to the GFCI rule.
Old 01-30-15, 07:17 AM
I
Received 45 Upvotes on 43 Posts
A sump pump that trips a GFCI is faulty and presents an electrocution hazard. Keeping it on the GFCI is the correct course of action. If you want to insure against flooding, add a second pump on a separate circuit or get a "backup" style that runs on 12V batteries or city water pressure.
Old 01-30-15, 08:09 AM
A
Received 5 Upvotes on 4 Posts
You can also get a GFCI with an audible alarm so that if it does trip, you'll know about it.
Old 01-30-15, 09:10 AM
CasualJoe's Avatar
Received 185 Upvotes on 166 Posts
Is it OK? It really depends on what version of the NEC and amendments your community has adopted. As I recall, 2008 and after requires the GFCI protection for all sump pump receptacles.
Old 01-30-15, 07:23 PM
D
I understand
As per written code use GFCI period....
However is my wiring proposal "schematic/layout" ok
I would be wiring 4 outlets in a chain the only difference is the the first outlet would be normal and the second would be the GFCI protecting the third and fourth downstream?
