Replacing two switches for two lights
Old 02-01-15, 08:49 AM
P
Hi all --
Sorry for the complete novitiate begging.
Pictures with everything numbered are here below and also uploaded here: http://imgur.com/a/padNW
Basically two separate switches operating two separate lights, but in the same box. They are independent of each other.
What I assume are the two grounds (#7 and #8) are screwed into the back of the panel.
#1 and #2 are coming down from somewhere, #3 and #4 are coming up from somewhere, and #5 and #6 are coming down as you can see from the right.
So, what goes where? If it's quick and easy for you, please help move my Sunday along! I've gone back up and down two flights over and over again to turn the power back off and on again so many times that I'm basically just doing it at random at this point!
-PJ
Old 02-01-15, 09:16 AM
Received 3,990 Upvotes on 3,581 Posts
Welcome to the forums.
You have 3) two wire cables. The first thing you need to do is identify which cable is the hot feed to that box. Turn the power on.... measure from each black wire to ground. When you find the 120vac..... check from that black wire to its white mate. Verify you have 120vac on a white and black pair. Let us know which pair and I'll tell you what to do.
Old 02-01-15, 11:39 AM
P
Thanks so much, PJmax!!
The hot feed coming into the box is wire #3, and I have 120vac on its white pair #4.
Old 02-01-15, 12:17 PM
CasualJoe's Avatar
Received 185 Upvotes on 166 Posts
The best thing to do is connect the new switches exactly like the original switches, assuming the old switches/lights worked.
Old 02-01-15, 12:34 PM
ray2047's Avatar
So that is your power in (hot) cable.
  • All whites wire nutted together.
  • Connect two pigtails to power in black (#3).
  • One pigtail to each switch.
  • One power out black to one switch.
  • Other power out black to the other switch.
Grounds connected per code. Pigtailed to the box since it is metal. Pigtailing to the switches is optional but best practice.
Old 02-01-15, 12:53 PM
I had a reply all typed up for you but I see Ray has taken care of you.
Old 02-01-15, 02:28 PM
P
Works wonderfully!
Thanks Ray2047 and PJMax for all of your help.
Looks like it will be another week or two before my wife finally learns how not handy I am.
Thanks, guys!
