Does splicing wire weaken the integrity of the run
Old 02-01-15, 11:50 AM
D
if running 12GA or 14GA house wire does splicing for necessary length dilute the strength or integrity of the circuit?
for example
i need to run 100' of wire for a chain of outlets and have 3 coils of wire,
one at 50' and two at 25'. is it OK to splice the lengths together rather than have to buy a new 100' roll?
if it is OK is there a maximum number of splices that can be on a run.
is this also OK for "home run type circuits" for washing machines, air conditioners etc?
of course the splices will be properly made and contained as per code
thanks for the advice
Old 02-01-15, 12:03 PM
Handyone's Avatar
It's OK and it won't cause any voltage drop AFAIK.
To me though it would be a pain. You would need junction boxes with covers, strain relief, etc. If metal, each box would need a ground pigtailed to box.
Maybe you have easy access to install boxes and that's not so hard.
Old 02-01-15, 01:20 PM
ray2047's Avatar
And the boxes must remain assessable, no burying in the wall.
Old 02-01-15, 04:17 PM
pcboss's Avatar
Received 201 Upvotes on 176 Posts
There should be no performance issues if properly made.
