Subpanel or Service Upgrade
Old 02-11-15, 12:03 PM
R
I currently have 150 amp service.
I have only two or three breakers free (Im not sure because a couple, in the past, have arced and i dont use that connection on the bus bar any more)
I plan to install a couple (maybe three) split system ACs this spring and probably an electric water heater (I currently have oil). So, I will need to use the last remaining spots and might even need a few more.
How do I determine if I need to upgrade to 200 amps or if I can just install a subpanel?
Old 02-11-15, 12:16 PM
I
Received 45 Upvotes on 43 Posts
You need to do a "demand load calculation" to determine the actual required service size. There are many calculators on the web to help you if you Google for it.
Old 02-11-15, 01:05 PM
R
Pretty confusing stuff out there!
But, this dumbs it down for me nicely.
Would you consider this to be reliable:
http://ask-the-electrician.com/resid....html#beginAdv
Old 02-11-15, 02:12 PM
I
Yeah that one looks good. An important note that I'm not sure it makes clear is to use your heat or air conditioning load, whichever is larger in terms of electrical load. Both should not be included.
