Electrical boxes in stucco
Hey guys, sorry for the noob post so soon. I have decided to do the electrical in my new home and trying to figure out the requirements for stucco. I can't find anything in the code book. For my service meter I know I need a stucco pan to maintain my air gap, but for my AC disconnects do I need this same thing? Below is a link to the disconnects I am using. These boxes are mounted to the block and I drilled a 1" hole to the interior that I plan on filling after running NM through it. The problem is my stucco guys are starting tomorrow and I need to make sure I get this right.
Square D QO 60 Amp Not Fusible AC Disconnect Switch Does Not Provide Overcurrent Protection-QO200TRCP - The Home Depot
The second question is, can I use 1/2" pancake boxes for my external lights? Again I drilled a 1" hole to the interior. Here is the link to the box.
Raco 1/2 Deep 4 in. Round Ceiling Pan with NMSC Clamps-8293 - The Home Depot
Final question. For my outdoor outlets can I use a standard wet location box? Again I drilled a 1" hole to the interior and intend to use the appropriate bubble box. Here is the product I used.
Red Dot 3/4 in. 4-Hole Single Gang Weatherproof Box-S106E - The Home Depot
Sorry for the questions. Should have asked these a while ago. Thanks.
The disconnect will be fine. A pancake would be perfect for the lights.
The FS (weatherproof) box would stick out of the stucco a bit but will work fine.
A pancake box will work if it only has one 14-2 cable. The capacity is not enough for two cables.
I would look at these options.Arlington | Non-Metallic FR Series Device & Fixture Box
I would not use a WP box in stucco. After a while the screws seize in the box and the box will need to be replaced.
