Unknown 70 amp breaker
Old 02-12-15, 04:13 PM
rayzzfish's Avatar
I have a electrical panel in my garage. It runs off a 100 amp breaker from my house. My house runs off a 200 amp breaker. There is a 70 amp breaker in the garage panel box. It does seem to hook up to any wires. I was wondering if I could take it out and put a 30 amp breaker. The reason for this is I bought a garage heater it runs off 240 volts with 30 amps. Any help or advice would be nice. I add a picture of my garage electrical panel. Thanks in advance. ..
Old 02-12-15, 04:16 PM
chandler's Avatar
Received 10 Upvotes on 9 Posts
Welcome to the forums! It may be a subpanel main controlling the remaining breakers. If you turned it off, does everything in the garage do dead? You may want to post a picture of the inside of the panel so we can see what you see. http://www.doityourself.com/forum/el...your-post.html
Old 02-12-15, 05:43 PM
rayzzfish's Avatar
Name:  GaragePanel (800x729).jpg
I finally got it. Picture was to big... lol Thanks for having me...
Old 02-12-15, 06:08 PM
ray2047's Avatar
Is this is a detached garage? If so then tha may have been intended to be used as a backfed breaker to provide the required disconnect.
Old 02-12-15, 07:50 PM
CasualJoe's Avatar
Received 188 Upvotes on 168 Posts
Is this is a detached garage? If so then that may have been intended to be used as a backfed breaker to provide the required disconnect.
Good point, Ray. The wires feeding the panel don't look big enough for 100 amps.
Old 02-12-15, 08:17 PM
ray2047's Avatar
I was also referring to the six throw rule. Anybody know if Canada also has the six throw rule? (More then six breakers a disconnect is needed if not in the same structure.)
Old 02-12-15, 08:24 PM
CasualJoe's Avatar
It looks like a 16 circuit main lug panel. I am sure that even in Canada a main breaker disconnect would surely be required, but I can't speak for sure about CEC requirements.
Old 02-12-15, 08:32 PM
ray2047's Avatar
If this is a detached garage and Canada has the six throw rule and if the 70 was intended to be the disconnect the next question is why isn't it being used. But first is this a detached garage?
Old 02-13-15, 07:24 AM
CasualJoe's Avatar
I would also be interested in knowing the size wire feeding the panel which is being fed from a 100 amp breaker in the house panel. It doesn't appear to be big enough for 100 amps. I also don't see a GEC so maybe this garage isn't detached.
I
Received 45 Upvotes on 43 Posts
My guess is that a previous owner used it to hookup some equipment like a welder or air compressor, or maybe even an illegal generator backfeed. Either way, it's unused now so I don't see any problem with swapping out the breaker for one to power your new heater.
Old 02-13-15, 07:27 AM
I
The ground at least looks to be copper -- I bet that's at least #4, which was legal at 100A not too long ago.
Old 02-13-15, 03:22 PM
rayzzfish's Avatar
I bought this house a year ago. The garage is attached. I think the house was built first and the garage added many years after. In the garage you see where a window was.
Name:  20150213_135801 (450x800).jpg
Size:  29.7 KB Name:  Our new house.jpg
Old 02-13-15, 04:05 PM
ray2047's Avatar
Attached garage so all is correct if the wire sizes are correct for the breaker in the main panel. Yes, just swap out the 70 for a 30.
