Pyramid PS-8KX 12 volt power supply failure
Old 02-15-15, 11:07 PM
F
I use this unit to supply power to a small 12v sump pump in my front yard. This is probably the 3rd or 4th unit I have replaced over the years. I leave it on all the time and live in Northern California so the pump doesn't get turned on a lot.
For the first time after a failure I got curious and I opened this unit up (I know a little something about 12v automotive systems but am a lightweight about AC.)
OK, here is what I found:
1. The output terminals read 13.89 volts (no load). If I put a load on it ( a small 12v bulb) it does not illuminate and the voltage drops to around 2mv.
So I opened it up, sort-kinda figured out how to connect directly to the output side of the transformer. Tested by connecting just after both the + and - diodes and it reads 11.58 volts. Add the same load at those points and it reads around .270 volts.
So I assume the transformer has failed since I am bypassing everything but the transformer and the diodes.
Now its no big deal to replace the unit as its around (another) 40 bucks. But I am real curious as to why it acts this way. Why would the output side of the transformer show about the right DC voltage until a load is put on it, and then with a load drop to near zero?
Old 02-15-15, 11:30 PM
Received 3,898 Upvotes on 3,494 Posts
Welcome to the forums.
The Pyramid power supplies are inexpensive and not always reliable. That unit is actually 6A rated.
When you measure the output of a transformer it is AC. Set your meter for AC and that transformer will probably show better than 16vac.
You should use a power supply rated at twice the amperage of the motor. You should probably be using a 10A supply or even a little larger.
Old 02-16-15, 11:51 AM
F
Pete,
Thank you for the reply.
