White Corrosion in Electrical panel?
Old 02-16-15, 10:42 AM
K
I opened up my panel to look at availability on the Neutral bars and noticed what looks like corrosion on a few of the screws (white corrosion.) I could feel cold air coming in the main feed through the conduit.
Shouldn't this be air-tight?
Is there supposed to be electrical putty surrounding the sheaths of the main lines coming into the panel?
What do I need to do?
KJ
Old 02-16-15, 10:49 AM
Received 3,422 Upvotes on 3,068 Posts
Some cold air is normal.
The service cable should be sealed outside at the meter.
Is this a pipe or cable service ?
Pictures are a big help to us. http://www.doityourself.com/forum/el...rt-images.html
Old 02-16-15, 10:56 AM
I
Received 45 Upvotes on 43 Posts
It should be sealed, yes. But often they are not, especially on older services. You can get a brick of "duct seal" for about a dollar and seal up the conduit(s).
Old 02-16-15, 11:59 AM
K
Here's a pic: The wind has been blowing crazy up here in New England, so I am feeling a breeze through the pipe.
Name:  Electrical Panel.jpg
Old 02-16-15, 12:02 PM
K
Can I seal from the inside with that duct seal? Just concerned if it would one day fall down onto the main leads.
Old 02-16-15, 04:08 PM
Yes.... you can seal the pipe inside but if you have water coming thru the pipe that must still be addressed.
Old 02-17-15, 06:24 AM
Tolyn Ironhand's Avatar
Received 676 Upvotes on 573 Posts
It should really be sealed on both ends. Duct seal is not conductive and you mold it around the wires like clay. It will not loose if properly installed. Do NOT use spray foam.
Old 02-17-15, 11:41 AM
pcboss's Avatar
Received 163 Upvotes on 142 Posts
The duct seal is a heavy putty consistency. It does not flow, but can be molded.
Old 02-17-15, 12:06 PM
F
Since it is a vertical conduit I would really prefer to use the ductseal on the upper end only to prevent trapping any water in the conduit.
