Disconnect for hot tub
Old 02-16-15, 01:20 PM
T
I am installing a disconnect for a hot tub. This is a used hot tub, owners have moved it from one house to another. Owner explains that the old location had a 50 amp breaker in main panel, no disconnect at old location. The majority of the disconnects I've been seeing is with 60amp. Does this really matter? I worked for an electrician for four years, but have been out of that line of work for about 2 years. Just like everything if you don't do it every day some things you just can't remember. Just want to make sure there is no difference, still using the same 50amp for the main panel. I haven't seen any of this yet just via the phone.
I'm already aware of the wiring that's required.
Old 02-16-15, 01:29 PM
Tolyn Ironhand's Avatar
Received 860 Upvotes on 723 Posts
Welcome to the forums!
A 60 amp breaker at the disconnect is fine as long as the wires are sized for the breaker that is in the main panel. The 60 is only a disconnect.
Old 02-17-15, 08:25 AM
CasualJoe's Avatar
Received 185 Upvotes on 166 Posts
And you have taken out the required permit? Will this be inspected?
Old 02-17-15, 12:33 PM
pcboss's Avatar
Received 194 Upvotes on 170 Posts
The 60 amp is the maximum that the disconnect can be used for.
Old 02-17-15, 01:08 PM
ray2047's Avatar
You need GFCI protection.
Old 02-17-15, 01:36 PM
B
In our area a GFCI disconnect is required at or near the hot tub. You can purchase those at the orange box store and they are 50 amp.
