Does exposed Romex under sink need to enclosed?
Hi,
I fished Romex thru the wall behind the dishwasher then drilled a hole in the adjoining wall under the sink to feed an electric box installed under the sink.
Thought I had done my due research, as in it's OK to fish Romex thru the wall without staples.
But now think I should have run Romex thru conduit where it comes out of the wall behind the dishwasher all the way to the outlet.
So can I sleeve that Romex in conduit right up to the hole in the wall? Doubt if I can leave the Romex exposed under the sink & behind the dishwasher as is?
thank you
thank you
Type NM cable is only required to be protected "where subject to physical damage". This is entirely a judgement call, but IMO, it is not.
You should secure the cable to the surface as required.
My opinion as well, that it would not be subject to physical damage. Behind the dishwasher, no one will get near it there unless they remove the DW. And we will certainly never endanger that 7 inch length of Romex under the sink but if we sell the house will it pass inspection. Imagine you'll say depends on the building codes in Denver.
thank you
thank you
You are not getting a code inspection if you sell the house. The home inspector may or may not say anything about this. Unfortunately they can write up anything they feel is an issue, even if it would pass code.
If you are concerned, you can move the box closer to the right side of cabinet and feed the cable into the box from side knockout
Thanks
I mistakenly thought the GFCI went under the sink, it is now in an outlet above the counter. A normal receptacle is now under the sink fed from the GFCI outlet above w/toggle switch. For a disposal.
Normally disposers aren't required to be GFCI proteced unless your area is on the 2014 NEC. Disposers aren't allowed to be on the small appliance branch circuits that serve the countertop receptacles unless the wirng is all existing from many years ago.
