Wiring outside floodlight
Old 02-19-15, 12:29 PM
Can I run a outside UF -b wire under my eaves/overhang to install a floodlights ? I would be running from another floodlight, attached to the house.
Old 02-19-15, 12:31 PM
Received 3,880 Upvotes on 3,477 Posts
UF-B is the correct wiring to use for your project.
Old 02-19-15, 01:55 PM
pcboss's Avatar
Received 194 Upvotes on 170 Posts
PVC conduit will look neater.
Old 02-20-15, 06:11 AM
Thanks...Yea I think the PVC would look better....what size for 14-2 wire ?
Old 02-20-15, 07:55 AM
ray2047's Avatar
14-2 isn't wire. It is cable. Best not to run cable in conduit. It just makes the job harder. Run black, white, green THWN conductors in " conduit.
Terminology: Cable is two or more conductors in a metallic or non metallic sheath.
Wire is a single conductor.
