Bathroom Exhaust Fan GFCI
Old 02-21-15, 10:20 AM
I am installing an exhaust fan in the ceiling between the shower and tub to get rid of moisture. I want to tie it into the same switch as the existing exhaust fan over the toilet which is not on a GFCI circuit. Can I just install a GFCI breaker on the bathroom circuit for the lights and existing exhaust fan? Is there any reason not to do that?
Old 02-21-15, 10:27 AM
Received 3,419 Upvotes on 3,065 Posts
Unless the fan can be reached from the shower or tub or is not directly over the tub or shower than a GFI shouldn't be needed.
You can certainly add one with no negative consequences.
Old 02-21-15, 10:36 AM
The shower and whirlpool tub are right next to each other so it would pretty much be directly over them.Name:  20150221_113400.jpg
Old 02-21-15, 04:53 PM
pcboss's Avatar
Received 163 Upvotes on 142 Posts
If it is over the footprint of either the instructions will call for GFI protection.
Old 02-22-15, 07:01 AM
CasualJoe's Avatar
Received 173 Upvotes on 156 Posts
If you do this, any GFCI receptacles on the circuit should be changed to regular 15A duplex receptacles.
