Transformer attached to outlet
Old 02-22-15, 03:53 PM
B
I recently bought a new house and in the dining room there is a big transformer plugged in to the outlet and screwed in to the wall. A wire goes from the transformer under the carpet and I have to idea where it goes. Does anyone have an idea what this might be for?
Old 02-22-15, 04:09 PM
Door Chime maybe ?
Unplug it and see what doesn't work!
Old 02-22-15, 05:05 PM
ray2047's Avatar
Not likely doorbell. Most likely for the alarm panel.
Old 02-22-15, 05:08 PM
Received 3,892 Upvotes on 3,489 Posts
Too tacky of a location for alarm. My guess..... LED or LV lighting.
Pull the transformer out of the wall and post what it says on it.
?? vac or ?? vdc ?? amps
Old 02-24-15, 05:57 PM
B
It appears to be the alarm panel. When I unplug it, the alarm panel is still lit, but it says "No AC".
Old 02-24-15, 06:27 PM
pcboss's Avatar
Received 194 Upvotes on 170 Posts
Many alarms have battery backups.
Old 02-24-15, 06:39 PM
Wow.... some alarm installation. That transformer should be plugged in an out-of-the-way location.
Old 02-25-15, 10:21 AM
ray2047's Avatar
And according to the O/P it runs under the carpet.
Old 02-25-15, 02:19 PM
F
I question if the wiring runs "under" the carpet as it looks to me like the jerk of an installer drilled a hole through the carpet into the basement and ran the cable. I could be wrong.
