Cigarette lighter plug on a coolbox
Old 02-22-15, 05:57 PM
Lightbulb Cigarette lighter plug on a coolbox
Hi all.
I'm Alex, novice in electricity, i try to fix a problem on my coolbox.
This box run on cigarette lighter, but the male cigarette lighter of my box is melted (i don't understand why..). I've cup the cable to put and other but i don't know the procedure.
I will buy a new male cigarette lighter but i don't know how i can join the new to the cable.
Thx for your help.
Alex
Old 02-22-15, 06:21 PM
Received 3,750 Upvotes on 3,362 Posts
Welcome to the forums.
The reason the plug melted is that there is a poor connection between the lighter plug and the lighter socket. The cooler draws some decent current which creates heat at the contact location.
That lighter plug is a very light duty one. Try to find something a little heavier duty.
There is polarity to the wiring. One conductor will have ridges on the outside of the jacket. Make sure that wire gets reconnected to the same contact it was on originally (center pin or shell)
Most lighter plugs are attached with a soldering iron.
You may have to clean or replace the lighter socket if it's corroded or rusty.
Look around for Safco lighter plugs. They can be installed without a soldering iron and they are good plugs. The last one from amazon.... buy the entire cord and chuck the cord and keep the plug. The plug can be removed and reinstalled.
CIG PLUG
SAFCO 12 Volt Cigarette Lighter #90 Fused PLUG - (Refurbished - Very Good)
amazon/gp/product/B009RN74AK/12v/lightercordassembly
