Extending 50A Aluminum #6 oven wire
Old 02-24-15, 06:38 PM
W
Question Extending 50A Aluminum #6 oven wire
Hi guys,
We have to move a 50A oven outlet down by about 2-3 feet. Currently it would be sitting on the higher end of the counter and to the left of the oven. Is it code for the outlet to be about 7-8 inches above floor level?
I think we have to move it which is why I have done some research on what needs to be done. The current cable has this name printed on it:
"BICCGENERAL -P FLEXILOY (TM) -3 CORS 6 AWG AL 1 COR 6 AWG AL TYPE SE STYLE R TYPE XHHW-2 CORS 600 VOLTS (UL)"
The cable has 4 wires, one of which is exposed ground wire. All the cables appear to be stranded (about 6-8 strands per wire) and are insulated.
I can't find a similar cable so the plan was to use 6-3 NM-B copper wires and connect them using the Polaris IPL4-3 connector. I know the Polaris connector does not support fine stranded flexible cable, but this is not fine stranded.
We haven't selected a range yet, but I can't imagine it would need more than 50A.
Please let me know what you guys think.
Thanks!
Old 02-24-15, 06:56 PM
pcboss's Avatar
Received 194 Upvotes on 170 Posts
You will need to make the splice in an accessible junction box.
The location of the receptacle depends on the unit installed. It is not a standard.
Old 02-24-15, 06:58 PM
W
Yes, it will behind the top cabinets. Am I using the correct parts to do this?
Old 02-24-15, 07:41 PM
pcboss's Avatar
The Polaris connectors are great and easy to use.
The box must be accessible through the cabinets.
