60/50 Hz problem with washing machine
My daughter has moved to South America, taking a UK washing machine with her. She has discovered that her 50 Hz machine won't run on the 60Hz there. How can she solve this problem ?
I have worked with conversions of different industrial machines, and never had that problem. It should be possible to solve but I need to know more than its not working. What's on the markings on machine, what is the voltage measured in the socket, are the water pressure different? E.g. We have typical pressure of 6 BAR here in Norway, but many places in UK they have far less...
What country, what "standards"??
dsk
dsk
Hi, cheaper you buy a new washer.
Frequency Converters, 60Hz, 50Hz, 400Hz | GoHz.com
Geo
Geo
Most SA countries has "110 V" even when having European style outlets, extremely confusing. You do have to check carefully to be sure. 50 and 60 Hz here and there, and that are usually no problem.
When you have a 110V system (110-125) it will often be available the double voltage.
A transformer 120V to 240 will be quite big to cover motor + heat elements of e.g. 2 kW, The heating may work at half voltage and give 1/4 wattage. No good solution, so we have to find something 208-250V 50-60 Hz
dsk
dsk
