Range hood lights
Old 03-01-15, 12:54 PM
I
Range hood lights
I'm hoping someone here can explain what I'm doing wrong here. I've included a diagram of the circuit. I have a SPDT switch to control two lamps. "Low" should illuminate only one lamp while "High" should illuminate both lamps. A diode is in the circuit to allow power to move from left to right. The diode that was in the circuit is a 1N5404. This is a range hood that was in the house when we bought it. It has always illuminated both bulbs regardless of the switch position. I thought the diode was bad and replaced it, but, that didn't change anything. The switch position in the diagram should illuminate both bulbs. Flip the switch and only one bulb should illuminate. Name:  diode_diagram.jpg
What am I doing wrong?
Old 03-01-15, 01:22 PM
F
That circuit would only work as described IF you had a direct current (DC) supply.
Old 03-01-15, 02:04 PM
I
Thanks for your response. This is what appeared to be OEM on the range hood. Is therte a way to accomplish my objective using something other than a 1N5404 diode? What did OEM mean by this wiring (note: it didn't work)-- never mind!
Old 03-01-15, 03:10 PM
I
I'm a novice when it comes to this, but, when you suggest a DPDT switch, that makes sense to me. That does mean I need to try to locate switches (fan and lights) that will match up to the opening. I'm still concerned as to what OEM was doing with this circuit (Nutone NS6500). I really appreciate the input. I wish I knew more about this stuff.
Old 03-01-15, 03:24 PM
Received 3,973 Upvotes on 3,566 Posts
You don't have the diagram drawn correctly.... plus both lamps should always light..... just bright or dim. I'll be back in a few with a diagram.
Old 03-01-15, 03:29 PM
I
Thanks Ray! Got it! Need to get the micrometer out and take measurements. I think this switch will work. I'll make sure I let the wife knows, "Ray solved this problem." Thank you so much! You too Furd!
Mod note: My solution was wrong. See PJ's answer below.
Old 03-01-15, 03:31 PM
This is how your lights should be wired. There is no polarity to the diode.
In high.... the 120vac is applied to both bulbs.
In low.... the diode is in series with both lamps. The diode blocks half the AC cycle and the lights are at half brightness. This circuit is used in hi/lo circuits everywhere.
Old 03-01-15, 03:43 PM
I
PJmax, what you diagram is probably what was there before the previous homeowner made changes. The bulbs are dimmable LED and am not seeing a difference in brightness. If I go to incandescence, I'll see a difference in brightness? I still need to think about the diode polarity you mention. Not sure what you mean.
Old 03-01-15, 03:50 PM
ray2047's Avatar
I have deleted my replies. Please follow PJ's instructions.
Old 03-01-15, 04:02 PM
The diode may have an effect on dimmable LED's but it will dim incandescent bulbs to half brightness.
If you try the circuit wired the way I illustrated with LED lamps.....diode polarity will affect the lamps.
Old 03-01-15, 04:04 PM
F
Well, gee, if I had known that you were okay with both bulbs dimming I would have suggested the same as PJ.
I don't know that you will get the desired result with LED bulbs. The circuit works well with incandescents because with the diode in the circuit the bulbs get power (pulsing DC) on only one-half of the AC cycle.
I
Thank you Ray, I appreciate your willingness to offer suggestions.
Old 03-01-15, 04:08 PM
I
I'm running out to get incandescence bulbs. I've struggled with this all weekend (and a closing Radio Shack!).
Old 03-01-15, 04:29 PM
I
With incandescence low has the right light brighter than the left, flip to high and the left light is brighter than the right. My wife and I think the output is the same, high or low. Matbe I should just give up! FYI, I'm still wired according to my original diagram, not what PJmax is suggesting. Too late to play with 120v. will consider following PJmax's recommendations tomorrow.
Old 03-01-15, 04:51 PM
ray2047's Avatar
It must be wired by PJ's diagram.
Old 03-01-15, 05:02 PM
I
I'll rewire tomorrow to PJmax's diagram. I really appreciate everyone's willingness to offer their knowledge.
Old 03-06-15, 11:16 AM
I
I finally found time to re-wire according to PJmax's diagram. It is now functioning correctly. Hi/Low is definitely noticeable with incandescent bulbs. I really can't see a difference with LED bulbs.
Thanks to everyone for advising me through this repair.
Old 03-06-15, 11:55 AM
ray2047's Avatar
Thanks for letting us know the outcome.
