Ceiling light extension box too far out
I bought an extension box to try and get the box level with the wood (by code) but it hangs out too far.
Do they make adjustable ceiling ring extensions? I can only find fixed ones.
I'm with Geo, I've had several instances where there just wasn't enough room for the electrical box so I cut a medallion out of wood to make up the difference. You can also buy premade ones but they are always white [can be painted]
Instead of an extension ring (box) maybe this would work: Cathelle: Simply Electric OCTAGON BOX EXTENSION - PLASTIC
I thought you couldn't use wood due to fire risk?
That's why the box has to be flush with the wood?
I can't access the area above and the junction box is screwed into a piece of wood above so can't move it upwards.
You mean put the wood above the junction box?
Very crude diagram of what the others suggested:
But isn't it a fire risk to put a wood ring onto the junction box?
If I put a wood ring around it then lights will not be flush, they will stick down.
The plastic ring looks suitable but not too easy to find in stores.
