240v surge protector for mini split
Duckless mini split VMH 09/12/18/24 SD
Surge protector 5-2-1 SD 60
240v installation
When hooking up surge suppressor I place leads in circuit breaker and also conductors in breaker correct. No place on suppressor to put conductors going to the outside unit disconnect
Thnx
240v installation
Thnx
Although it maybe best to be on it's own breaker I have seen many doubled up on 2 pole breakers as long as the terminals on the breakers are rated for 2 conductors,is this your suppressor ?
Hard Start|Hard Start Kit|Start Capacitor|Compressor for air Conditioning|Start Assist|5-2-1 Compressor Saver|5-2-1|521
Geo
Geo
Some surge protectors do not have separate "line" terminals to connect to a feed line or a breaker and "load" terminals to connect the air conditioner unit or other device or electronics to be protected. These surge protectors may be connected anywhere in the house electrical system provided they have proper overcurrent protection as their instructions specify.
Duckless -- Has no components for which duck tape is commonly used to hold together or aid in the installation.
OT: Other cavalier use by me of trademarks: "... romex cable of the same gauge works just as well for audio as monster cable or oxygenated cable although it might not be as attractive looking ...
