Wiring a table saw
Old 03-13-15, 07:55 PM
A
Wiring a table saw
I have a Delta table saw that has a 230v 20 amp motor. I am wondering what size wire and breaker to run for this. i will run this across the top of my basement and up into the wall of the garage. Do I need to put this into conduit to get through the garage wall as well? Thanks
Old 03-13-15, 08:20 PM
Received 3,759 Upvotes on 3,370 Posts
Welcome to the forums.
If it is exposed in the garage it should be in pipe. If it's inside the garage wall just NM cable would be fine.
240v at 20A sounds a little high. The motor should only draw around 10A at 240vac.
For anything under 15A motor load.... #12 would be fine.
Old 03-13-15, 08:43 PM
CasualJoe's Avatar
Received 179 Upvotes on 162 Posts
What is motor horsepower?
Old 03-14-15, 05:08 AM
chandler's Avatar
Received 9 Upvotes on 8 Posts
We'll wait on the OP to respond, but my Delta Unisaw at 5hp may run as much as 20 amps. I only have it protected at 20 amps on 240 volts and it operates fine. He may be reading FLA, too.
Old 03-14-15, 05:47 AM
Geochurchi's Avatar
Received 159 Upvotes on 145 Posts
What does the mfg. recommend for wire size and breaker?
Geo
Old 03-14-15, 08:12 AM
W
Received 63 Upvotes on 55 Posts
Wiring
All wiring passing through masonry walls must be in conduit.
