Plug replacement flat 3 wire cord
Received 0 Votes
I need to replace fridge plug.
The 3 wire power cord is flat, similar to this:
The replacement plugs I have seen at the hardware store have a rounded entry point where the plug clamps to the cable with a grommet. This cord is flat and square though.
What type of plug replacement can I use then?
My other option is a $100 wiring harnass kit direct from whirlpool where I would plug in the new cable inside the cabinet with a molex connector. The fridge is 8 years old so I am not sure that is a very smart option.
Received 0 Votes
Yes, I "googled" it. I cannot find one for a flat cable as pictured. All of them have rounded grommet area where the plug clamps to the cable.
Also... Im thinking they are not intended to be replaced. I am assuming the conductors are molded into the cable itself... as opposed to having individual, insulated conductors inside.
No, Just cut the cord from the harness inside the refrigerator and splice on a cord set. You may need to add a junction box to the frame. Or what I'd probably do is wrap the cord where it enters the plug with enough tape so the strain relief clamp has a good grip.
Received 0 Votes
Yes, I could lap off the cord and splice a new cable to it too.... but I don't think underwriters labratory or whirlpool would agree.
Still wondering what the proper replacement plug would be for a flat, 3 wire appliance cord.
If you are looking for something with a UL approval then you might end up having to spend the $100. Or you can look at the replacement plug options and see if they can still perform the task you need. Even a round strain relief can sometimes grip a flat cord. Or, you could slit the flat cord near the end to allow the three conductors to be moved forming a triangular shape that can be better gripped by the round strain relief. After all, a strain relief is there to prevent the cord from pulling out or damaging the plug. Tucked away safely behind a fridge it's likely to not get touched again for years.
Received 0 Votes
Let me ask this, my reason for wanting to replace the cord in the first place...
The ground prong appears to have been bent upwards a bit. In fact I may have done it intentionally years ago when it wasn't inserting into an old outlet quite so smoothly.
If you grasp the ground pin with your fingers you can slightly jiggle it.
The bending of the ground pin however, does not interfere with inserting the plug... when you do so it bends back a bit. In addition to that, I tested for grounding with my multimeter and their is continuity between the pin, the fridge chasis and the electrical system.
So perhaps this is a non issue? Thoughts?
If you measured proper grounding on the frame of the fridge then don't mess with the plug.
There are a few plugs that will work on a flat cord for future reference.
amazon/Leviton 5266-CA 15 Amp, 125 Volt, Angle Plug, Straight Blade, Industrial Grade
amazon/Leviton-515AN-Angle-grounding-White/dp/B00004YUKX/
Received 0 Votes
Where do you see that those Levitons are compatible with flat cords?
Pass Seymore makes an identical looking 90 plug as the one in your link. In the directions to that device, it says it is only for ROUND cable. I assume the Levitons are the same unless your seeing something that says otherwise.
They aren't specified for one type of cable. I carry them and use a rubber grommet if I have a fit issue.
It this was a plug removed on a daily basis then it would be a different story. Then you'd need to find something custom designed to fit flat cable and be right angle. The only right angle version I've seen was injection molded..... not screw together.
