Am stuck in the islands trying to install sub-panel
Old 03-17-15, 05:10 PM
L
Am on an island and thought I understood how to connect a new sub panel, but am now getting 2 differing suggestions.
Adding a DEH-1309 sub panel on other side of wood stud from existing main panel.
Am running the 4 wires thru 3" metal conduit with metal lock nuts on side if each panel box side.
Just noticed that the new sub panel has the 2 main lugs for main wires, but only one bar which I thought was for the white neutral connection back to main panel.
Am getting 2 different opinions on the green ground wire from main.
Do I connect the green ground direct to the neutral bar holding the white neutral, or do I have to order a TLG2 ground kit to add to the sub panel for the green ground?
Does the metal cabinet to metal cabinet connection between the 2 panels mentioned above make any difference here?
Any help would be greatly appreciated, and thanks
Old 03-17-15, 05:36 PM
Received 3,892 Upvotes on 3,489 Posts
The existing bar that comes in the new panel is insulated from the panel and is for the neutrals.
You need to add a grounding bar that connects directly to the metal box of the panel.
You could use bonding locknuts and then technically you wouldn't need the ground wire and bar but if you plan to connect circuits.... you'll need the ground bar anyway.
Old 03-17-15, 05:45 PM
L
Thanks much, and failed to remember the connecting new circuits.
Before I power it all up, can I post a picture to make sure I have it wired correctly...not a lot of fire departments here.....
Thanks again.
Old 03-17-15, 05:58 PM
chandler's Avatar
Received 9 Upvotes on 8 Posts
Sure, we would appreciate the pictures. Usually complete series of pictures showing all the connections in both boxes will help, too.
Old 03-17-15, 06:32 PM
ray2047's Avatar
Old 03-17-15, 07:33 PM
L
Thanks Ray... Will post some pix....
Because...... we don't have any fire trucks here.....
Old 03-17-15, 08:02 PM
CasualJoe's Avatar
Received 185 Upvotes on 166 Posts
Technically you can only use the grounding locknuts if the knockouts are eccentric. If you have concentric knockouts with rings remaining, you'll have to use bonding bushings. In each panel you need to connect the bonding bushing to the appropriate bar; ground bar in subpanel and neutral bus in main panel. IF you do this, you do not need to run the 4th grounding conductor, but you will still need the ground bar kit in the subpanel. You can still run a 4th ground wire if you so desire.
Old 03-20-15, 03:44 PM
L
Status up with some questions....
These pictures show my “planned connections”, as once these pix were taken, I disconnected all connections between the panels and turned power back on.
(Also, have come to realize I need a couple specific connectors that are having to come in from the State next week.)
Have two #4 wires (black with blue tape) going from sub to main.
Have one #4 wire (black with white tape noting neutral status) going from sub (connected) to main, but not connected because I have to order another neutral bar lug connector for this connection.
Have one #6 wire (green) going from sub (connected) to main, but also not connected at main because I also need a ground bar lug connector.
Have also connected 2 breakers in sub panel, but the #12 wire is not connected as I need a breaker here.
NOTE – Had to use pvc connector for the time being until I get a ¾’ lock ring for the 10-3 wire coming into sub on lower left.
All ground wires in sub panel are not connected, because I also had to order a ground bar kit for this sub panel which goes in the right side of sub panel box.
Questions….
Am I on the right track with wires and connections?
Am a little concerned about the limited space in which to install the neutral bar lug on the neutral when I receive it…any suggestions? May have the same situation with the ground bar connector that I have to install on the ground bar on main panel.
The main panel is a Siemens G11224ML1125, an older panel, but was told Siemens bars use the same lugs, so ordered a ECCS1 for the ground bar, and a ECLK2 for the neutral bar.
Finally, and this just came up. Please note the second smaller 30 amp breaker in sub panel which I was sold, but it has 2 connections, and am not sure if I got the wrong breaker here, as the large double 30 amp breaker has 2 connections which I was told was for my 10-3 wire and I connected the red/black, but only have a 10-2 going to the smaller breaker (only have the black wire)…..where did I go wrong?
Many thanks for looking at these and any help is greatly appreciated…..as they say here… island construction ain’t for sissies….
Old 03-20-15, 06:27 PM
pcboss's Avatar
Received 194 Upvotes on 170 Posts
The smaller breaker in the sub panel looks like a tandem and not a 2 pole breaker. A 2 pole breaker is needed for a 240 volt load.
Old 03-20-15, 08:36 PM
CasualJoe's Avatar
I see some double lugging going on in your main panel. Where is the main breaker?
That second smaller 30 amp breaker in the subpanel will give you two 30A 120V circuits.
Old 03-21-15, 05:01 AM
L
Casual Joe, am not sure what is meant by "double lugging"?
Cottage was built with a main breaker outside at the meter. which then directly feeds into this main panel located in the cottage where there is a 100 amp breaker.
These are the only "main breakers" I have.
Old 03-21-15, 05:18 AM
chandler's Avatar
Double lugging is where there are two wires attached to the screw on a breaker. Some breakers are fine with double lugging and have places for a wire on each side of the pressure plate. It is usually best to pigtail both wires into a single wire and attach that wire to the breaker. The main breaker at the meter is fine. He just wanted to make sure you had one since the boxes you have are main lug type and not main breaker type.
Old 03-21-15, 06:23 AM
L
Thanks for all the help from everyone.
Any thoughts/experience in adding a second lug connector to the neutral and ground bars in the main panel....
Although I won't get these connectors for another week, am not sure where to put them on the bars as space looks very tight?
Also, I connected the 2 panels with a 3" pipe thru the stud, and then secured them with metal locking rings. Does this type connection mean I won't need to run that green ground wire between the main panel to a new ground bar (yet to be installed) on the sub panel?
Thx again.
