Dead power in master bedroom
Old 03-19-15, 08:05 PM
Ok so last night I was building a tent in the living room for my kids to camp out in for fun. I went into the Master bedroom to blow up an air Matress. I plugged a charger in the wall and turned it on. As soon as I turned it on all of the power went off in the room. I went outside to check the breaker box and none of the breakers tripped. To be proactive just in case I reset all of the breakers. Went back inside and it was still off in the master bedroom . Then I went into the garage to get a flash light and the garage light did not work. I also noticed the pantry light in the kitchen was off . Being the fact that I'm not an electrician and that is a skill and trade I know nothing of I called my neighbor down the street. He is a commercial electrician but I thought better him looking at it then me. He looked in the room and said " You must have a GFI" I told him there was one in the master bedroom bath by the sink. He went and looked and the power was dead to it as well. He had a replacement and went ahead and swapped it out and bam it had power. So he then went to the socket I plugged the charger into to start and he recommended us replacing it as well as it was a bit worn. He quickly swapped them out but still no lights or power other than the GFI. Then he went out to check the breaker box . All of the breakers checked to be good. Then he checked the ground bar in the box and all grounds were connected and no loose wires. We looked at a bunch of different sockets throughout the house and all we good just no power or lights in the master bath and garage light . He and myself are pretty stumped . I'm looking for any suggestions at this point.
Old 03-19-15, 08:34 PM
ray2047's Avatar
You don't need grounds for lights and receptacles to work. It was probably the neutral bar.
Look outside and every other bathroom for a GFCI. Look in the garage. Look behind furniture and other things that haven't been moved in years for another GFCI.
Have you read: http://www.doityourself.com/forum/el...ther-info.html?
