Cable securing - Horizontal through studs and multiple gang plastic boxes
Received 0 Votes
Question 1 - Is cabling secured making a long (25') run horizontally through studs?
Meaning, through holes I'm about to drill in the studs. Code says to fasten every 4.5 feet to a surface over which it runs. Since I'm more running "through" surfaces rather than "over" them, I'm confused whether this means to fasten during the 25' run or not.
I know it has to be secured once it starts moving vertically over the studs. (Down from the panel, down to the outlet box.)
Question 2 - Code says when using a single gang plastic box, the cable doesn't have to be anchored if it is supported within 8" of the box and at least 1/4" of the sheath extends into the box. What do I do with two gang plastic boxes? Have I overlooked a cable clamp meant for plastic boxes?
The remodel plastic boxes have integrated clamps. You need to punch it out a little to break the factory nibs, but after that you can push a cable through and it will hold.
If using new work boxes, the knockout will offer no strain relief. The staple within 8" is sufficient.
Technically, when remodeling and using "old work" boxes, no securing (stapling) of cable is required for the inaccessible parts of the run.
