Help with receptacle wiring
Old 03-21-15, 03:12 PM
G
i have a light switch. Turn it on, overhead lights go on. There is an AC outlet wired to it. It ONLY works if the switch is off. Two wires only to both switch (for overhead lights) and the AC outlet. Can i change something to get the ac outlet permanently on? Thx!
Old 03-21-15, 03:28 PM
ray2047's Avatar
We will need to know the wiring at the light.
Old 03-21-15, 03:30 PM
chandler's Avatar
Received 9 Upvotes on 8 Posts
Welcome to the forums! You have a "through" wire on the switched side. What did you do to the wiring? Can you post a picture of the switch pulled from the box showing the wiring at the switch and inside the box. Power off, for sure.
Old 03-21-15, 04:55 PM
Geochurchi's Avatar
Received 159 Upvotes on 145 Posts
How many cables are at the light fixture ?
Geo
