Electrical receptacle polarity.
Hi
I just checked one of the outlets in my house. It returns as Hot Neutral. Is this safe or do I need to replace it? If it is safe, why was it set like this?
I attached a picture and it is the one above the "CORRECT".
Thanks
https://www.dropbox.com/s/g0sf6rrz0i...12301.jpg?dl=0
Thanks
Does the receptacle work if you plug in something like a table lamp ?
If it doesn't work you may have lost the neutral to the receptacle. If it does work then the receptacle is most likely connected backwards and should be corrected.
it works but i am concern because my wife has been plugging her laptop into it for an entire year.
To most devices.... your laptop included..... the polarity at the receptacle wouldn't make a difference. However, if you notice.... some appliances/devices have one wider and one smaller prong. Those are called polarized plugs and they require the correct wiring.
Best to change it as soon as possible.
Good point on the wider vs normal prongs.
How was it install wrong in the first place and how do I correct it? Do I just switch the places between the white and black wires?
Thanks
Thanks
http://www.doityourself.com/forum/el...rt-images.html
If you're unfamiliar with basic wiring, it might be better to post a picture of the receptacle.
Gently pull it away from wall. Tilt receptacle down and try to get a good picture showing the back of receptacle. Showing the back should also give a fairly clear view of wires inside box.
Hot Neutral Reverse
The incorrect wire connections can be at the problem receptacle or at the connections of the supplying cable at the upstream receptacle.
Hi, I have not gotten a chance to take it apart yet and post a picture. I do have a question before doing so. This receptacle is on a 15 amp circuit. I have a couple of new 20 amp receptacles (has not been used yet) at home which I installed a few around the house last year. Can I replace this 15 amp receptacle with a 20 amp receptacle or does it need to be exactly the same?
If I have to buy a new 15 amp receptacle, is there anything in particular should I be looking for? I believe the current one is just a standard one.
Hi,
I just replaced it the receptacle and tested it.
So the reason why it showed as Hot Neutral as mentioned in my original post, the previous owner must of connected the wires backward. They connected the black wire to silver screw instead of the brass screw. And the white wire to the brass screw.
It is a 20 amp circuit so I replaced it with a 20 amp receptacle.
Ray, in your above post, I could have put a 15 amp receptacle on this 20 amp circuit? The one that I just removed is a 15 amp receptacle. Please confirmed.
Thank you for the confirmation.
Last question, would there be any reason why the previous owner connected the wires backward (black with silver)? Or was it just a simple mistake on their part?
You can but those adapters are extremely light duty and basically junk. You'll find the receptacles loosen up quite quickly and the plugs don't stay in tight.
You'd be better off using a good power strip.
