Mini arc furnace
Old 03-24-15, 12:06 PM
Mini arc furnace
I've seen Grand Thompson do it in one of his videos and I would like to recreate it, but he is using a modified microwave transformer and I've read that it is not really recommended if you don't know what you are doing.
Link: https://youtu.be/d5pGN6pqkyY?t=35s
What I am looking for is a transformer I could buy that would fit my needs.
I'm living in Canada so if it's simpler for you just tell me the specs of the transformer that i would need and I'll try to find a place where I could get one.
Here's a video on the arc furnace.
Link: https://youtu.be/VTzKIs19eZE?t=2m43s
Old 03-24-15, 12:39 PM
Received 3,881 Upvotes on 3,478 Posts
Welcome to the forums.
That transformer delivered +/- 800A at 2v. That would be a costly transformer to buy.
It's very similar to a welding transformer but lower voltage and higher current.
Start by looking on eBay for high current low voltage transformers.
Old 03-24-15, 12:53 PM
I just searched for microwave transformer on ebay and found many like in the video. Thanks i just have to find the other parts. Have a nice day
Old 03-24-15, 02:09 PM
F
Many decades ago I would make arc lamps using a glass jar with two pieces of steel strapping banding bent over the side of the jar. Connect one band (electrode) to the power, the other band to one carbon and the other carbon back to the power. Fill the jar with water and add salt until you can get a continuous arc.
The jar of salt water is acting as a ballast resistor and the amount of salt you add controls the current to the arc. You DO need to keep an eye on the temperature of the water as it will rise with continuous use, the bigger the bottle the better.
