need help with wiring tanning bed
I have a sonnen braune Wolff system 628 tanning bed that I bought used it does not have a manual with it it is a240 vac 60 hz with neutral single phase total wattage 3237 I'm needing to know how to wire it up
Certainly not much info to go on but looks like a 20 amp 240 volt circuit would handle it.
Have you tried to contact the mfg?
Geo
Geo
Welcome to the forums.
Lie Geo mentioned... a 20A circuit would handle the job. You will need to run 12-3 w/ground cable.
Is there a cord and plug on the unit that you'll need to match ?
Have a look at this chart and let us know which NEMA configuration matches the cord on the tanning bed. It is probably 6-15 or 6-20, but please confirm.
It looks like it is the 14-30
Yes it has 4 prongs it doesn't look like someone added it it looks like it came that way. My husband checked it out it has 4 wires going to it. I can't add pic all I got is my phone Internet not a regular computer
It looks like you would install a circuit for this thing exactly like a cloths dryer. Double-pole 30A breaker in the panel, 10-3g NM-B (Romex) cable out to the bed location, and a 14-30 dryer receptacle to plug it in.
