Reload this Page >
Converting fan/light dimmer switch to a single pole switch
Old 03-28-15, 02:38 PM
T
Greetings,
I am looking for some guidance regarding a new switch installation. I replaced an old fan with a new one that has a remote control. The old fan was operated by 2 dimmer knobs, one controlled the lights and the other controlled the fan. The new fan seems to be having some light problems (blinking, dimming, etc) before i can get it to work. I am assuming it's because of the old switch.
I would like to replace the old switch with a single pole switch, but I am not sure which wires go where.
This is the back of the old dimmer switch. The next pic is the inside of the box. There is a black wire connecting the red wire on the old switch, a black wire connecting the black wire on the old switch, and a red wire connecting a yellow wire on the old switch. I did cap a red wire on the new fan.
Not sure which wires to connect to the next switch pic.
Hope this wasn't to confusing, but i believe i am way overthinking this.
Thanks for all the help.
T
Old 03-28-15, 03:12 PM
pcboss's Avatar
Received 194 Upvotes on 170 Posts
The black is probably power into the old switch. The red and yellows are the switched hots out to the fan and light.
Old 03-28-15, 08:39 PM
T
Thanks for rhe reply, but i am not sure which wires to connect to the new single pole switch. Do i cap off the red and connect the two black wires?
Thanks
Old 03-28-15, 08:45 PM
pcboss's Avatar
The hot will need to connect to one of the screws on the switch. The other two wires will connect to a short pigtail of wires that connects to the other screw on the switch.
A green or bare jumper from the metal box can ground the switch. You will need a 10-32 screw to connect to the box.
Old 03-29-15, 05:51 PM
T
Do i need to pigtail or can i just cap off one of the wires?
Old 03-29-15, 05:54 PM
pcboss's Avatar
If you cap off one of the wires one function will not work.
