Above sink light wiring question.
Old 03-30-15, 09:23 AM
W
Removed existing light, here is what I found. I have 3 lines, 1 is the continuation of the circuit, one is a junction off of that to provide power to a plug directly below in the basement. The 3rd line is to the switch. How can I wire in the new light to make sure I continue the power down below (unswitched) to the plug and yet wire the switch in to control the light?
Old 03-30-15, 09:34 AM
ray2047's Avatar
The only connection that you should of touched was the two wires to the light. Those two wires are connected to the new lights.
Old 03-30-15, 10:21 AM
W
I didn't alter anything that was done. Was just surprised, as your diagram shows, the grounds were not connected. The only problem was, all of this was done without the use of a junction box.
Old 03-30-15, 10:27 AM
pcboss's Avatar
Received 194 Upvotes on 170 Posts
The grounds must all be connected and an approved junction box used.
Old 03-30-15, 11:22 AM
ray2047's Avatar
Not the intent of the diagram. Grounds were only omitted for clarity. As is noted on the diagram grounds should be connected according to code..
