Finding what a switch controls
Old 03-30-15, 10:34 AM
B
Received 2 Upvotes on 2 Posts
Is there any tricks to find out what a "dead" switch controls? In my house I have several switches which seem to do nothing. They do not seem to control receptacles or obvious lights. They are definitely LIVE.
Old 03-30-15, 11:17 AM
ray2047's Avatar
How do you know? If you used a non contact tester you don't know for sure. Is there a cable coming into the box that when disconnected using a multimeter reads ~120v between black and white?
Old 03-30-15, 11:34 AM
Received 1,248 Upvotes on 1,192 Posts
The most common reason I've seen for a 'dead' switch is a switched receptacle - either still switched and no one knew about it or no longer switched but the wires just disconnected and the switch left to fill the place in the box.
Old 03-30-15, 12:54 PM
ray2047's Avatar
Adding to what Stickshift said. Sometimes someone replaces a half switched receptacle and doesn't remove the tab. You might look for receptacles close to the switch that has more then 4 wires (two cables or two cables, one with a red ).
