Pump Motor Start Relay
Old 04-02-15, 12:53 PM
R
Need help identifying connection tabs on a MARS2 17325 contactor.
There are no markings and no wiring diagram in the box.
Need 230v in, 230v out,
24v coil pick pair and if both AC & DC pick , which is which.
Old 04-02-15, 01:55 PM
Geochurchi's Avatar
Received 158 Upvotes on 144 Posts
Not exactly sure what you are looking for,that is a pretty standard Contactor ,line in the top load out the bottom, terminal on the sides are for your 24VAC. I would suggest that the set screw lugs be used for the terminations, if this doesn't help please show us your application so we may be able to assist.
https://www.google.com/search?q=wiri...ml%3B456%3B447
Geo
