Running leaf blower off a drop cord?
Old 04-04-15, 08:40 PM
B
I noticed my electric leaf blower is gettiing a bad connection and is smoking at where I connect the drop cord to it.It also leaves a black stain at the connector..Does drop cords go bad?Do I need to replace my drop cord?This is a brand new leaf blower so i know its not the leaf blower.Could it be because I am plugging the drop cord through a GCFi circuit?Gcfi circuits is all I have in my garage though.
Any help/advice would be appreciated.Thanks
Old 04-04-15, 08:46 PM
CasualJoe's Avatar
Received 185 Upvotes on 166 Posts
The female cord cap on the cord probably needs to be replaced. Does the plug on the leaf blower fit loosely in the female cap?
Old 04-05-15, 08:01 AM
Received 128 Upvotes on 113 Posts
A GFI has nothing to do with it.
Should be using at least 14 gauge wire cord.
Yes the female ends wear out.
Do not cheap out when replacing it.
Leviton 15 Amp 125-Volt Rubber Grounding Plug-R60-515PR-000 - The Home Depot
Old 04-05-15, 08:14 AM
Norm201's Avatar
Received 716 Upvotes on 637 Posts
As Joe mentioned, a heavier gauge cord is most likely the cause. The longer the cord the heaver it needs to be not to exceed manufactures recommendations. If your having that kind of trouble or if your cord is over 50 to 75 feet you should consider a gas powered unit.
Old 04-05-15, 12:36 PM
W
Received 63 Upvotes on 55 Posts
Replace End
Do Not replace the female end with this. You will have a suicide cord if you do.
Old 04-05-15, 03:11 PM
F
When I read/hear the term "drop cord" I am reminded of the guarded light bulb that my daddy used when working on cars. It had #18 conductors and the ones today may have #16 conductors.
You should NEVER use an extension cord with less than #14 conductors and even that is probably not sufficient for the leaf blower. With only one exception ALL of my extension cords are either #12 or #10 conductors.
I know those heavy extension cords are expensive but they ARE necessary unless you don't mind burning up your tools and maybe even your house.
