Wiring Bathroom Fan/Light
Old 04-08-15, 01:50 PM
G
Power comes into 2 gang using 14/2
- 1 switch to power vanity light using 14/2
- 1 switch to power fan/light combo using 14/3
Question:
1. Do I need a 3 way switch (terminal screw) for fan/light combo?
Old 04-08-15, 02:01 PM
pcboss's Avatar
Received 163 Upvotes on 142 Posts
You do not want a three way switch. Three way switches are for when you want to control something from two locations.
You want a single pole or two single pole switches if you want independent operation of the fan and light.
Old 04-10-15, 07:21 AM
G
@pcboss: thanks. Given there are 2 hots with 14/3, how are the wires configured with regard to the switch and power coming in?
Old 04-10-15, 07:39 AM
Handyone's Avatar
If you want to switch the fan and light separately (which you can do with the 14/3), you will need 3 switches in the box:
1 for vanity light
2 for fan/light combo
You can do this one of two ways:
- Cut out old box and install an old work 3-gang box
- Use a double stacked switch for controlling the fan/light
Once you decide, we can help you with wiring. It's pretty straightforward.
You also have the option of keeping only 2 switches, but the fan and light will be switched together and that defeats the purpose of running 14/3
Old 04-10-15, 11:52 AM
G
Correct. I thought is to use a double stacked switch for controlling the fan/light.
Old 04-10-15, 02:33 PM
Handyone's Avatar
At the switch box you technically have 3 switches; 1 normal and 1 stacked.
- Connect source neutral to 14/3 neutral going to fan/light and neutral going to vanity light
- Connect 2 black pigtails to source hot wire. 1 hot will go to vanity light switch terminal, doesn't matter which one. Other hot will go to stacked switch common terminal. Common terminal will be marked (dark) or letters embossed on back of housing.
- Hot going to vanity light will be connected to remaining terminal on vanity switch
The fan and light:
- The 14/3 red and black wires will be connected to the stacked switch brass terminals, there are two. I would put light at top and fan at bottom.
Old 04-10-15, 03:03 PM
ray2047's Avatar
Do not break the tab on the duplex switch.
Old 04-11-15, 06:25 AM
G
The stacked switch has 2 black terminal screws. How is this handled?
Old 04-11-15, 06:30 AM
ray2047's Avatar
As I wrote the two black screws of the duplex switch have a tab between them that is not removed. Therefore you only need to connect to one since they are electrically connected. (It doesn't mater which screw.) If the tab has been removed post back.
